Table llx boxes def
Revision as of 16:09, 23 May 2009 by Eldy (talk | contribs) (moved Boxes def (Table SQL) to Table llx boxes def)
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contains the active boxes
Contient les boîtes actives
Contiene las cajas activas.
Structure
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | PRI | NULL | auto_increment | technical index | |
file | varchar(255) | box file.php | ||||
entity | int(11) | 1 | multi company id | |||
tms | timestamp | CURRENT_TIMESTAMP | last update date | |||
note | text | YES | NULL | comments |
