Table llx bank
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Contenu
Contient les opérations effectuées sur les comptes bancaires.
Contains the transactions operated on bank accounts.
Contiene las transaccions efectuadas en las cuentas bancarias.
Structure
| Field | Type | Null | Key | Default | Extra | Description |
| rowid | int(11) | PRI | NULL | auto_increment | technical index | |
| datec | datetime | YES | NULL | date of creation technical | ||
| datev | date | YES | NULL | value date of the transaction | ||
| dateo | date | YES | NULL | date of the transaction | ||
| amount | double | 0 | amount of the transaction | |||
| label | varchar(255) | YES | NULL | label | ||
| fk_account | int(11) | YES | NULL | account number on which the transaction took place | ||
| fk_user_author | int(11) | YES | NULL | ID of user author of the information (llx_user->rowid) | ||
| fk_user_rappro | int(11) | YES | NULL | ID of user author of the rapprochement (llx_user->rowid) | ||
| fk_type | varchar(4) | YES | NULL | transaction type | ||
| num_releve | varchar(50) | YES | NULL | number of summary of the bank on which the transaction | ||
| num_chq | int(11) | YES | NULL | number of check if significant | ||
| rappro | tinyint(4) | YES | 0 | indicates whether the line was rapproched or not | ||
| note | text | YES | NULL | note | ||
| Author | varchar(40) | YES | NULL | |||
| fk_bordereau | int(11) | YES | 0 | Id du bordereau de remise de cheque | ||
| banque | varchar(255) | YES | NULL | name of the bank received the check | ||
| emetteur | varchar(255) | YES | NULL | name of the issuer of the check |
