Table llx adherent options
Revision as of 07:14, 15 May 2009 by Simnandez (talk | contribs)
Contenu
  Contains the optional attributes of members of the association module
  Contient les attributs optionnel des adhérents du module association
  Contiene los atributos opcionales de los miembros del módulo miembros
Structure
optid int(11)   PRI NULL auto_increment technical index
tms timestamp CURRENT_TIMESTAMP last update date
adhid int(11) ID of member (llx_adherent->rowid)
