Prerequisites
Dolibarr was build to work on following components :
OS
- Every OS are supported.
For example: Linux, BSD, Windows, MacOS, Aix, ...
Database
- Mysql 3.1 or + (4.1 or more is recommanded)
If using option mode=STRICT returns some warnings or error, please report them to us.
- PostgresSql (experimental support not working yet)
- MSSql (experimental support not working yet)
PHP
- Version 4.3.10 or more (need support of the "%0.2F" of the sprintf PHP function to make PDF generation working)
- Support of user sessions must be enabled (it is the cas by default in PHP)
- Works whatever is the parameter register_globals
- Works whatever is the parameter magick_quotes
- Works whatever is the parameter safe_mode
- PHP configuration must allow use of a max of 16Mb of memory (24Mb required if using Windows).
