Translation system
Revision as of 22:46, 8 April 2009 by Eldy (talk | contribs)
Development rule
In Dolibarr code source, translations are made by using a method available on object $langs with the key to translate as parameter of this method. The $langs object contains definition of use language. This object is always defined in all pages.
There is 2 methods:
  • $langs->trans('TRAD_STRING');
This methode return translation of key TRAD_STRING, and encode result into HTML entities to allow to output it correctly (even with special characters) into an HTML page.
  • $langs->transnoentitiesnoconv('TRAD_STRING');
This method return translation of key TRAD_STRING, but result is translated string with no particular encoding (string is stored in UTF-8 in memory).
This 2 methods can accept arguments that will be used to replaced strings %s found in resulted translated string.
Note: If, as arguments, you use a string that is itslef a translated string, you must use method $langs->transnoentitiesnoconv, otherwise string will be encoded twice. Example: print $langs->trans("STRING_TO_TRANSLATE",$langs->transnoentitiesnoconv("STRING_PARAM1"))
Translate Dolibarr into another language
See page Translator documentation
