Module Virtual Warehouse
| Module name | Virtual Warehouse |
| Editor / Editeur | Milen Karaganski - http://blacktiehost.com |
| Download or buy page / Page achat ou téléchargement | External module - dolistore.com blacktiehost.com github.com |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2021-06-15 |
| Note / Nota |
This module helps you manage your stock to show REAL quantity, when you have items in your Sales representatives.
When a record is created, the QTY set to the Sales representative is removed from the stock in Dolibarr, thus showing in product card the real stock you have in your warehouse.
Main page of the module helps you track products and their Qty you have in your sales representatives.
This is a free module, available at https://www.dolistore.com/, https://blacktiehost.com/shop/dolibarr-modules/virtual-warehouse-v1-0// and github.com [1]
Support is available at: admin@blacktiehost.com
