Module Membership management
| Foundations | |
| Numero/ID of module | 310 |
| Developer doc. of module | Module Foundations (developer) |
- Define several types of member.
- add/Validate/Edit/Resiliate/Delete a member card (characteristics, photos, ...)
- Manage subscriptions is required or not.
- Add/Edit/Delete subscriptions.
- With module EMailing, send mass emailings to members or to a selection of members.
- With module LDAP, synchronize members with a LDAP.
- With module Banks and Cash, interface your subscriptions with treasury of your foundation.
- Reporting.
- Generic export with Module Exports.
Creation of a member type
Creation of personalized attributes
New or renew a subscription
Membership instalment payment
Take the case of a membership paid for in three instalments. Ask your member for three cheques, the sum of which is equal to the subscription they owe. Then, for dolibarr, the principle is the same as above.
Once you have clicked on New membership, enter the counterparty corresponding to the first cheque, and specify the period of validity, in our case this corresponds to 1/3 of the year. Then, in the Label field, enter Membership Year 1/3, for example. Then click on Add membership. Repeat the operation twice more, adjusting the values to cover the whole year.
Revoke a member
Related videos
