Module Knowledge Management
| Knowledge Management | |
| Numero/ID of module | |
| Developer doc. of module | Module Knowledge Management (developer) |
Also called KM (Knowledge Management) or KMS (Knowledge Management System), this module allows you to manage a Knowledge Base.
