Module Hide Fields in Cards and Forms EN
Information
Module name Hide Fields in Cards and Forms
Editor / Publisher AIME
Download or buy page DoliStore
Status Stable
Prerequisites Dolibarr min version: 24.0 PHP version: 7.4 - 8.3
Last update date 2026-08-06
This module allows users to hide fields and columns that are not used in Dolibarr cards and forms, making the interface simpler and faster for daily data entry.
It can be used on third parties, invoices, orders, proposals, and products.
- Download the module from DoliStore.
- Copy or extract the module into Dolibarr's external modules directory.
- Enable it from Home - Setup - Modules.
Once enabled, the module adds an edit mode to hide or show visible fields in cards and forms.
Only a user with permission to configure field visibility can hide or unhide fields.
Changes are not applied per user or per profile. Hidden or visible fields apply to the whole current entity, so all users work with the same configuration.
- Enable the module edit mode.
- Click the field or column you want to hide or show.
- Save the applied changes.
For more usage details: View full usage guide
Support
- Technical support: soporte@aime.mx
- Sales inquiries: info@aime.mx
