Module DMS Audit Control
| Editor | DMS — Dolibarr Module Solution (dolibarrmodulesolution.com) |
| Module ID | 194318 |
| Version | 1.0.0 |
| Dolibarr | 18 to 24 |
| PHP | 7.4 or later |
| Where to get it | Ask DMS by email (DoliStore publication in progress) |
| Support | support@dolibarrmodulesolution.com |
| Presentation and videos | dolibarrmodulesolution.com |
DMS Audit Control spots the gaps in your Dolibarr data, such as an order delivered but never invoiced or an overdue invoice, and helps you put them right.
An order shipped but never invoiced, a payment not allocated to any invoice, an overdue invoice nobody chases. These oversights cost money, and they are often found too late.
DMS Audit Control compares your orders, invoices, payments, projects and contracts, and turns each inconsistency into an anomaly. You follow it through to its correction from a single cockpit. The module reads your data without ever rewriting your sales documents.
What the module gives you
- 13 ready-made checks: shipped order without an invoice, signed quote without an order, unallocated payment, overdue invoice, finished project still open, contract without an invoice, and more.
- A cockpit that sorts anomalies by severity and status, with their trend over seven days.
- An anomaly list with filters, assignment to a colleague and an overdue badge when the handling time has been exceeded.
- Assisted corrections from the anomaly record: create the missing invoice, send a payment reminder, close a project.
- Automatic resolution: at the next check, an anomaly whose data has been corrected moves to "Resolved" on its own.
- Your own checks, built in a three-step wizard without writing a single query.
Day to day
- The Data audit control top menu opens the cockpit. One click on "Run control" analyses your data, or the check runs on its own if you enable the scheduled job.
- Each anomaly is assigned to the right person, who handles it from its record and keeps its history.
- An Anomalies tab appears on the relevant Dolibarr records, and home page widgets show critical anomalies and your own.
- An email can alert the people you choose as soon as an anomaly reaches the severity you set.
Frequently asked questions
Does the module change our invoices or orders?
No. The check reads your data and records what it finds in its own tables. An assisted correction always goes through a normal Dolibarr action, after you confirm it. The module only ever deletes anomalies, never your documents.
What is the module called inside Dolibarr?
In the module list and in the top menu, it is called "Data audit control". DMS Audit Control is its product name and the name used in its documentation.
What happens to an anomaly we decide to ignore?
It stays ignored, even if the situation persists: it does not come back and does not cause a new email to be sent. Only the "Reopen" button on its record brings it back into the list of active anomalies.
Videos
Home → Setup → Modules → "Deploy/install external app/module", upload the zip file and enable the module. Nothing in Dolibarr itself is modified, so Dolibarr updates keep working.
Support
Questions before installing, or a problem with the module: write to support@dolibarrmodulesolution.com. The module page, with its videos, is on dolibarrmodulesolution.com.
