Products
Numero/ID of module 50
Developer doc. of module Module Products (developer)
This module manage a catalog of products.
See also Modules Services to manage a catalog of services or page Module Stocks to manage warehouses and stock.
Definition
Products
A product is a good to manage as it is an object you sell to customers or it is an object you buy from suppliers. It is a material good, contrarily to Services.
A product follows this rules:
  • A product can be stocked into a warehouse (only products appears in module Stock. Services are not visible).
  • A product can be delivered (only products appears in module Shipment. Services are not visible. Services are realized but can not be shipped).
  • A product is a material good. It's value often decrease with time (Value of an already used product is lower than same never used product).
Virtual products (also called Pack products)
  Page waiting for translation. To translate, create an account, go back and clic on "Modify".
  Page en attente de traduction. Pour traduire, créez un compte, revenez et cliquez sur "Modifier".
  Página a traducir. Para traducirla, cree una cuenta, vuelva a la página y haga clic en "editar".
  Pagina da tradurre. Per tradurla, crea un utente, torna indietro e clicca su "modifica".
  Página a aguardar por tradução. Para traduzir, crie uma conta, volte atrás e clique em "Modificar".
  Seite wartet auf Übersetzung. Um Übersetzung zu erstellen, richte einen Account ein, geh zurück und klicke auf "bearbeiten".
  页面等待翻译。若要翻译本页,先创建一个帐户、登录并返回本页后单击“编辑”。
Un produit ou service virtuel est un produit père, constitué d'autres produits. Cette fonction s'active depuis la page de configuration du module Produits ou Service. Elle a pour vocation à définir des "packages" ou "lots" de produits qui permettent de raisonner sur les commandes, factures et stocks avec un seul élément au lieu des n produits constituant le lot. Translation: A product or service is a virtual father product consisting of other products. This function is activated from the Products module or service configuration page. It aims to define "packages" or "batches" of products that allow to reason about orders, invoices and inventory with a single element instead of the n products as Lot.
  • Lors de l'ajout d'un produit dans un document (propositions, facture, commande), seule la ligne du produit virtuel père est affichée.
  • Le stock de produit composant le produit virtuel est incrémenté/décrémenté quand le produit virtuel est incrémenté/décrémenté.
  • Un produit virtuel peut lui même être constitué d'autres produits virtuels qui eux contiennent de vrais produits.
Translation: A virtual product complies with the following rules:
  • When adding a product in a document (proposals, invoice, order), only the line of virtual product father is shown.
  • Product stock component virtual product is incremented / decremented when the virtual product is incremented / decremented.
  • A virtual product may itself be composed of other virtual products that contain them real products.
Remarque: Il ne s'agit pas d'une fonction de "fabrication/production" où les produits fils composant le produit virtuel seraient consommés du stock pour obtenir un produit père supplémentaire en stock. Ici, les sous-produits composants un produit virtuel ne sont décrémentés du stock qu'au moment de la consommation du produit virtuel et restent des sous-produits consommables de manière indépendantes des autres, contrairement à un de module de fabrication, où lorsque qu'un sous-produits est utilisé pour fabriquer un module père, le sous produits est décrémenté du stock même si le produit père n'est pas encore distribué, et souvent ce sous-produits ne peut plus faire le chemin inverse pour revenir en stock. Translation: Note: It is not a function of "manufacturing / production" where the virtual product component products are consumed son of stock father for an additional product in stock. Here, the sub-components produced a virtual product are decremented stock at the time of consumption of the virtual product and remain independent manner consumables byproducts other, unlike a manufacturing module, wherein when that a by-product is used to manufacture a father module, the products under the same stock is decremented if the father product is not yet distributed, and often this byproducts can no longer do the reverse way back in stock.
Life cycle / Business rules
  待完成,欲帮助完成,注册帐号,点击“编辑"
Examples of use cases
UCMP01:
Situation
Actions
