Module Products
Revision as of 17:12, 6 August 2009 by Eldy (talk | contribs)
Products
Numero/ID of module {{{num}}}
Developer doc. of module Module Products
This module manage a catalog of products.
Definition
A product is a good to manage as it is an object you sell to customers or it is an object you buy from suppliers. It is a material good, contrarily to Services.
A product follows this rules:
  • A product can be stocked into a warehouse (only products appears in module Stock. Services are not visible).
  • A product can be delivered (only products appears in module Shipment. Services are not visible. Services are realized but can not be shipped).
  • A product is a material good. It's value often decrease with time (Value of an already used product is lower than same never used product).
Life cycle / Business rules
To complete
Examples of use cases
To complete
