Module Multi-currency
| Multi-currency | |
| Numero/ID of module | 40000 |
| Developer doc. of module | {{{devdoc}}} |
This native module add the support for multi-currency in Dolibarr ERP CRM.
Once in the setup page, enable all the different currencies you need with their rate compared to your main currency (the currency used for the accountancy of your company).
Once the module is activated and currencies to use selected, you can select a different currency on each proposal, sales or purchase order, customer or purchase invoices. The known rate of the foreign currency will be automatically used and amounts on the documents will be shown in the both currencies (your main currency and the foreign currency).
You are still able to set a different rate for each document. Also, when registering payments on invoices, you will be able to enter the amount into the foreign or the main currency.
