Using Dolibarr node in the n8n automation platform
Revision as of 19:11, 5 May 2023 by Lpierson002 (talk | contribs) (→‎Credits: adding link to AuTEAMation)
If you want a tutorial to the integration of Dolibarr to the n8n automation platform you can find it here.
Prerequisites
The following tutorial assumes that you have completed the following prerequisites:
  • You have access to an instance of Dolibarr configured to use SSL encryption (with the HTTPS protocol),
  • You have access to a user account with rights to use some specific modules such as Calendar, Project or Documents,
  • You have obtained an API key for your user account that you will use to test your integration (generated by an administrator, or by the user himself if he has permission to modify his user account information).
When necessary, we will use the following URL to refer to your Dolibarr instance: `https://yourdolibarrurl`. You will have to replace it with the URL of your own Dolibarr instance, without trailing slash.
Connecting to n8n
As explained in previous parts, once you have created your n8n self-hosted instance on your computer and started it with the command : n8n start or n8n.
Then you just have to press o on your terminal to open n8n in your browser.
You should arrive to the following connexion screen where you can enter your connexion informations.
Connecting to n8n
Creating a Workflow using Dolibarr Node
When you have signed in, you can create you first Workflow and selected the Dolibarr node.
To do that, you just have to click on Add Workflow to create one and click on the + to add a node to your Workflow. It will open a search bar in which you can search dolibarr to find it.
Dolibarr node
Explanation of the different functionalities
Different scenarios
Here are the different Dolibarr functionalities we have implemented in n8n.
General informations
Credentials
A Dolibarr node needs to have set up credentials in order to connect your Dolibarr instance to n8n.
You can connect to your Dolibarr account from the `Credentials` tab or directly from a Dolibarr node.
Credentials
You have to indicate you base URL which is your instance URL.
And your API key that you can find in your account parameters when connected in Dolibarr.
Fields in every node
For every Dolibarr node there will be some fields that will be the same.
These fields are the first three one on the picture below :
  • Credential to connect with  : this is where you can set your credentials as explained just before,
  • Resource : this is where you choose which module of Dolibarr will be affected, there are 4 options : Calendar, Task, Document and Custom API Call (use this one only if you know what you are doing),
  • Operation : this is in this field where you select the kind of operation you want to do on this specific resource, for now it only supports creation operation.
Creating a Calendar Event
The first node is used to create an event in the calendar in Dolibarr.
Add event in n8n
If you have selected the Create an Event operation and have alreary set your credentials the first three fields will be already completed.
For the next fields :
  • Event Name corresponds with the Label field in Dolibarr interface (this field is required),
  • Description corresponds with the Description field (this field is optional),
  • Event Type corresponds with the Type type field, three options are available : Intervention on site, Meetings and Reception of Email (this field is required),
  • Beginning Date of Event corresponds with the left date in the Date field (this field is required),
  • End Date of Event corresponds with the right date in the Date field (this field is required),
  • Email From is not corresponding to any field for now on Dolibarr but since this field is present in Dolibarr API, it is possible that is the next updates a dedicated Mail Sender field will be available on the Dolibarr interface (this field is optional),
  • Email Subject is also not corresponding to any field for now on Dolibarr and as the previous one we can expect that a dedicated field appears is the next updates (this field is optional).
Add event in Dolibarr
Creating an event in Calendar when an event is created in Google Calendar
To produce this use case you will have to connect a Google Calendar Trigger node on the Dolibarr node.
The Google Calendar Trigger node documentation can be found here.
Once you have set up the Google Calendar Trigger node you can connect it to the Dolibarr Create an event node.
One possible configuration to have the wanted informations is to enter to same informations as in the screenshot.
Be sure to select Expression mode on fields that use the previous node informations.
You can either type or drag and drop from the left window which field you want to have from the Google Calendar Event.
Here :
  • $json.summary corresponds to the Google Caldendar Event Name,
  • $json.htmlLink corresponds to the Google Caldendar event URL (doing this is optional since description can be empty as explained before, entering the URL only facilitate the Google Calendar event access from Dolibarr),
  • $json.start.dateTime corresponds to the starting time of the Google Calendar event,
  • $json.end.dateTime corresponds to the ending time of the Google Calendar event.
Creating an event in Calendar when an email is received
To produce this use case you will have to connect an Email Trigger node on the Dolibarr node, for example the Email Trigger (IMAP) node or the Gmail Trigger node.
The Email Trigger (IMAP) node documentation can be found here and the Gmail Trigger node one here.
As before, when you have set up the trigger node you can connect it to the Dolibarr Create an event node.
Creating an event in Calendar when an email is received before update
For the example of configuration, this is the Email Trigger node case that will be presented since it is the more general case. One possible configuration to have the wanted informations is to enter to same informations as the screenshot.
You can either type or drag and drop from the INPUT window on the left which field you want to have from the received mail.
Here :
  • $json.subject corresponds to the subject of the mail,
  • $json.textPlain corresponds to the email sender,
  • $json.from corresponds to the body of the email,
  • $json.date corresponds to the date when the email was sent.
The Gmail Trigger node will be similar, you can find the desired field using the INPUT window on the left in Schema mode to help yourself.
Creating an event in Calendar when an email is received after update
The second screenshot correspond to a possible configuration of the `Dolibarr Create an event Node` with the `Email Trigger (IMAP) node` when the `Email From` and `Email Subject` fields will be implemented in the Dolibarr interface in future updates.
Creating a document
The second node is used to create a document on a specific Dolibarr module.
Add a document in n8n
If you have selected Create a document and have alreary set your credentials the first two fields will be already completed.
  • File Name corresponds to the file name is Dolibarr, it is important not to forget the file extension if you want it to have one (this field is required),
  • Module Name corresponds to the Dolibarr module where the file will be created (this field is required),
  • Reference corresponds to the `Ref.` of the object to which the file will be linked (this field is required),
  • File Content corresponds to the content that will be written in the file (this field is optional),
  • File Encoding is an additionnal field that needs to be activated if you want to add file with formatting, like pdf which needs to be encoded in base64 (this field is optional),
  • Overwrite File if It Already Exists ? is an additionnal field that when activated will allow file overwriting if the File Name entered already exists (this field is optional),
  • Create Subdirectories if Necessary ? is an additionnal field that when activated creates a Subdirectory for your file if this is necessery (this field is optional).
Add a document in Dolibarr Document Gestion containing Zoom meeting information
To produce this use case you will have to connect an Zoom Get Meeting node on the Dolibarr node with a n8n Trigger node at the beggining of the workflow.
The Zoom node documentation can be found here.
As before when have set up the node you can connect it to the Dolibarr Create an event node.
One possible configuration to have a Zoom meeting informations is to enter to same informations as on the screenshot.
Here :
  • $json.topic corresponds to the topic of the Zoom meeting,
  • $json.host_email corresponds to the email of the person who host the Zoom meeting,
  • $json.duration corresponds to the duration of the Zoom metting,
  • $json.timezone corresponds to the time zone where was done the Zoom metting.
Besides, a .docx file extension is added to generate a file compatible with LibreOffice Writer, this format does not need File Encoding.
This file will be added to the Agenda Event associated with the Zoom meeting, in the example this is the event with the Reference n°33.
Finally, the additional Field Overwrite File If Already Exists ? is activated to be able ot overwrite the file with more or different informations from the Zoom meeting if wanted.
Creating a Project Task
The third node is used to create a task in the project module of Dolibarr.
Add task in n8n
If you have selected Create a Task and have alreary set your credentials the first three fields will be already completed.
  • Task Reference corresponds with the Ref. field in Dolibarr interface, the Task Reference is a string that must be unique, (this field is required),
  • Project ID corresponds with the Child of project field, this is a number corresponding to the id of the project from which the task will be a child (this field is required),
  • Task Name corresponds with the Label field (this field is required),
  • Starting Date corresponds with the left date in the Date field (this field is required),
  • Ending Date corresponds with the right date in the Date field (this field is optional).
Add task in Dolibarr
Creating a Task in Dolibarr when a Github issue is received
To produce this use case you will have to connect a Github Trigger node on the Dolibarr node.
It is important here if you are using a self-hosted instance of n8n to start it in tunnel mode. To do so, just run the following command : n8n start --tunnel.
To trigger on receiving issues select the type Issues in the Events field.
The Github Trigger node documentation can be found here.
Once you have set up the Github Trigger node you can connect it to the Dolibarr Create a task node.
One possible configuration to have the wanted informations is to enter to same informations as on the screenshot.
You can either type or drag and drop from the left window which field you want to have from the Github Issue.
Here :
  • $json.body.repository.name corresponds to the name of the Github repository,
  • $json.body.issue.title corresponds to the title of the issue,
  • $json.body.issue.body corresponds to comment leave on the issue,
  • $json.body.issue.created_at corresponds to the creation date of the issue.
Conclusion
This tutorial helped you understand how to configure a Dolibarr node in n8n and how they work in order to make you build the example use cases or custom use cases using already existing Dolibarr node functionalities.
Credits
This tutorial was produced by the AuTEAMation team as part of the design of interfacing prototypes between the Dolibarr ERP/CRM and several automation platforms for DoliCloud. This study was carried out as part of the PFA, a 2nd year group project at ENSEIRB-MATMECA.
