Module Products (developer)
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Products
Numero/ID of module 50
User doc. of module Module Products
Feature
The Product module allows you to manage a catalog of predefined products.
Entity Product
The PHP class to use to manipulate such object is file htdocs/product/class/product.class.php.
Permissions
  • ->produit->lire
  • ->produit->creer
  • ->produit->commander
  • ->produit->supprimer
  • ->produit->export
Tables SQL
