Triggers system
Revision as of 13:51, 6 July 2012 by Lrq3000 (talk | contribs) (Added priority number details)
Execute your own code on a Dolibarr's action
To execute personalized code after a Dolibarr event (create/modify/remove a third party/invoice/product or other), Dolibarr offers a mechanism of business triggers. This mechanism allows you to personalize a work-flow to have Dolibarr business events being synchronized into another application for example. You can also use triggers to modify the behavior of Dolibarr itself: for example, to create automatically a contract when an invoice is validated.
1) Copy the trigger file htdocs/core/triggers/interface_20_all_Demo.class.php under the new name:
  • interface_99_all_Xxx.class.php
or
  • interface_99_modMyModule_Xxx.class.php
where Xxx is a string of your choice startint with uppercase character, 99 is the priority number for the execution of your trigger (1 being the top priority) and MyModule is the name of a module if you want that trigger is activated only if module MyModyle is activated. If you want the trigger to be always active, use all instead of modMyModule. This new file must be saved inside same directory.
Note: Value you can use for modMyModule are values found in directory htdocs/includes/modules.
For example, you can name your new trigger file: htdocs/includes/triggers/interface_99_modFacture_Myworkflow.class.php
Note: With Dolibarr 3.2+, you can also place the triggers in your own module's subdirectly. Eg: if your module resides in htdocs/mymodule/, then you can place your triggers inside htdocs/mymodule/core/triggers/. But for this, you must declare the trigger into your module descriptor file (eg: /mymodule/core/modules/modMyModule.class.php). For this, add into this file triggers->1 into module_parts array:
//              'login' => 0,
//              'substitutions' => 0,
Then disable and reenable your module. This will add a record into Table llx_const to say Dolibarr a trigger file must be searched into module directory htdocs/mymodule/core/triggers/
2) Edit the file interface_99_modMyModule_Myworkflow.class.php to rename class InterfaceDemo by InterfaceMyworkflow
Then go on page Home-> System Infos -> Dolibarr -> Triggers. Your new trigger file must appears in the list without any error message. This means preceding actions have been done successfully.
3) Return now to edition of file to add your own code inside function run_trigger. This function is called at each Dolibarr business event. Put your code according to events on which you want to run. Each event is identified by a code (see following chapter to get full list of codes). So you can react or no after an event by doing just a test on variable $action:
  • $object is the object on which action is done (see next chapter)
  • $user is the object containing all information of Dolibarr user that realizes the business event.
  • $langs is the object that contains the user language and translations strings
  • $conf is the object that contains all the Dolibarr configuration.
4) Once your trigger file has been developed, last action is to test by using Dolibarr to execute the business event that should trigger your code. Warning, call of function run_trigger is encapsulated into a transaction. If your code return a KO code, the calling function may rollback the transaction (this depends on calling function). Add log information inside your function run_trigger to know if your code is correctly triggered and runs correctly. For this, you can use the function dol_syslog("my log message", LOG_DEBUG);
List of known triggers actions
List of all events that launch triggers are available in Table llx c action trigger. This is a quick list of those events, identified by value of variable $action into trigger code and type of variable $object for each code:
USER_CREATE user.class.php
USER_MODIFY user.class.php
USER_DELETE user.class.php
USER_LOGIN user.class.php
USER_LOGOUT user.class.php
PROPAL_CLONE propal.class.php
BILL_CREATE facture.class.php
BILL_MODIFY facture.class.php
BILL_CLONE facture.class.php
BILL_PAYED facture.class.php
BILL_CANCEL facture.class.php
BILL_DELETE facture.class.php
DON_CREATE don.class.php
TVA_CREATE tva.class.php
TVA_MODIFY tva.class.php
TVA_DELETE tva.class.php
TVA_ADDPAYMENT tva.class.php
TASK_CREATE task.class.php
TASK_MODIFY task.class.php
TASK_DELETE task.class.php
PAYBOX_PAYMENT_OK
PAYPAL_PAYMENT_OK
TICKET_CREATE ticket.class.php
TICKET_MODIFY ticket.class.php
TICKET_DELETE ticket.class.php
TICKET_ASSIGNED ticket.class.php
TICKET_CLOSE ticket.class.php
Manage and create a new trigger's action
To manage other events on objects than the one defined before, you mist edit the Dolibarr code to add the following code inside the business method of the class file of the object:
// Call triggers
// End call triggers
Here, $this contains the business class with all information to send to the trigger functions. Replace 'XXXXX_YYYYY' by an event code not already used. Then you will be able to add inside the run_trigger method, a "if" to manage this code. The run_trigger method will contains a part of code like this :
      <b>
      if ($action == 'XXXXX_YYYYY')
      </b>
Conclusion
See also
