Module Products
Revision as of 08:26, 5 January 2010 by Simnandez (talk | contribs)
Products
Numero/ID of module 50
Developer doc. of module Module Products (developer)
This module manage a catalog of products. See also Modules Services to manage a catalog of services.
Definition
Products
A product is a good to manage as it is an object you sell to customers or it is an object you buy from suppliers. It is a material good, contrarily to Services.
A product follows this rules:
  • A product can be stocked into a warehouse (only products appears in module Stock. Services are not visible).
  • A product can be delivered (only products appears in module Shipment. Services are not visible. Services are realized but can not be shipped).
  • A product is a material good. It's value often decrease with time (Value of an already used product is lower than same never used product).
Associated products
Associated products are products attached to a parent product.
An associated product follows this rules:
  • When adding a product into a document (proposal, invoice, order), only the line for parent product is shown.
  • Stock of subproducts are increased/decreased when parent product stock is increased/decreased.
Life cycle / Business rules
  待完成,欲帮助完成,注册帐号,点击“编辑"
Examples of use cases
UCMP01:
Situation
Actions
