Module Membership management
Foundations
Numero/ID of module 310
  • Reporting.
Dolibarr can manage your bank accounts but does not manage accoutancy. This means Dolibarr does not suit needs of a big foundation (more than 5000 members). There is also no salary management module. The foundation management modules is however a very god choice if your foundation as a budget lower than 10 000 euros/dollars a year.
Creation of a member type
Creation of personalized attributes
New or renew a subscription
  Page waiting for translation. To translate, create an account, go back and clic on "Modify".
  Page en attente de traduction. Pour traduire, créez un compte, revenez et cliquez sur "Modifier".
  Página a traducir. Para traducirla, cree una cuenta, vuelva a la página y haga clic en "editar".
  Pagina da tradurre. Per tradurla, crea un utente, torna indietro e clicca su "modifica".
  Página a aguardar por tradução. Para traduzir, crie uma conta, volte atrás e clique em "Modificar".
  Seite wartet auf Übersetzung. Um Übersetzung zu erstellen, richte einen Account ein, geh zurück und klicke auf "bearbeiten".
  页面等待翻译。若要翻译本页,先创建一个帐户、登录并返回本页后单击“编辑”。
Résiliation d'adhérent
Example of use case
UCFO01: The foundation wants to define a new type of members
Situation The foundation wants to define a new type of members
Actions I create a new type from Menu foundation - Setup - Members types - New type.
UCFO02: A new member come with a cheque or cash
Situation A new member come with a cheque or cash
Actions I create the new member from Menu foundation - New member.
If you want this member to have a Dolibarr access, click on "Create a user" from its member card view. If you want this member to be a third party to send him proposals, invoices, etc, click on "Create a third party" from its member card view. I create a new subscription from tab subscription of member card.
UCFO03: A member come to renew its subscription with a cheque or cash
Situation A member come to renew its subscription with a cheque or cash
Actions I go on the member card then tab Subscriptions.
I add the new subscription.
UCFO04: I want to revoke a member
Situation I want to revoke a member
Actions I go on the member card.
I click on Revoke.
